I was thinking about building a Aleph 3, but I don't see many boards available for this design.
This is the only one I've seen so far:
PASS LABS CLONE - ALEPH 3 Amplifier PCB
I also see some assembled boards on eBay, but I would rather solder my own components onto the board:
Class A Single Ended 2 Pass A3 HiFi Amplifier Board IRF9610 IRF244 30W 30W DC25V | eBay
Does anyone know of any other sources for Aleph 3 boards?
Thanks...
Thanks...
Hi Ammel,
Have you considered the chipamps pcb set?
Aleph through-hole PCB Set | Chipamp Electronics
Dennis
Dennis
Hello Dennis,
No, I didn't know about those boards. They look really nice and seem to accommodate different versions of the Aleph amplifier.
He doesn't state how to use the boards with 4 output devices. I assume you would mount the 4 devices on the output boards and leave the 2 off the main board?
Thanks...
Thanks...
Yes, the mosfets would go on the output boards. Here are a couple of posts that
illustrate the hook up.
http://www.diyaudio.com/forums/pass...ld-aleph30-needs-some-help-2.html#post3786045
http://www.diyaudio.com/forums/pass-labs/249554-beginner-build-aleph30-needs-some-help-19.html
Dennis
Dennis
