Soundstream Tarantula 800/5 needs repair Help!!
I have a Soundstream Tarantula 800/5 (The Huge Chrome one with the Handles) Hooked up to a pair of Soundstream exact 10's in a ported box. When the volume is up loud and a lower bass note hits (say around 30hz or lower) the amp cuts out. If I turn it down a little then its ok. Anyone have any idea what this could be? any help would be nice. Thanks in advance.
IMOP sounds to me like u have to low of a laod on the amp.
OR maybe your subs cant handle the power from the amp and making the amp shut off.
First question how do u have your subs wired to the amp and are the subs single or dual voice coils and if dual coils how do u have them wired
Right, could be protecting because of low load or also could be you have a power problem like a bad ground or fuse holder/etc. If power drops to about 10v at amp they shut off. If the amp has an LED for power often they will dim down a lot if you have power issue.
I dont think the ohm load is the issue. The subs are Single 4's So I have them wired to a 2ohm load. Was fine for a year and just started doing it. I wired 2 Soundstream SPL 10's to a 4ohm load and the same thing happened. (Put the Exacts back it 🙂 I dont know whats going on lol
Check the volts at the amp with it cranked up, if it falls to 11v or less DC then that could be it. Is it getting hot? If you swapped the subs likely not them. Is that amp supposed to run 2 ohms on sub channel? Double check all wiring and connections just to be sure.
yes I have, I have even wiggled wires when the volume was only a few clicks away from being at the point that it usually shuts down. Nothing.
Pic of amp in question
If it shuts down with the other signal line driving it, it's almost certainly not the head unit or a signal line problem so it's either a voltage problem (which you said you eliminated as a possibility), a speaker problem (may only short at extreme excursion), a wire problem (unlikely since it only does it at low frequencies) or an internal problem with the amp. Before going into the amp, you need to eliminate every possible cause outside the amp.
