OK so that answers that. I bet they used TO-220 cases.
BTW not to prod on anybodys previous argument, but there seems to be several data sheet versions of the TIP142/147 in terms of SOA. Theres the TO-220, TO-218, and TO-247 data sheets for these. Each seem to have slightly different SOA, especially the TO-218 which may be higher rated than even the TIP102/107s with TO-220 package.
Likely only the TO-220 package would fit anyway.
I'm going to try and stay away from TIP142/147 setups. Just a personal decision.
Thank you
Thank you
These amplifiers use the 'T' suffix parts. They only come in one package style and there is only one data sheet to pay attention to. Ie.
https://www.mouser.com/datasheet/2/149/TIP142T-890084.pdf
