on old school soundstream reference picasso blue board chrome amp is it possible to use the balance line input without the BLT module. can anyone give me a pinout of the balance line input. i want to send my pioneer p880prs speaker outputs straight to the balance line input. i understand there is a +/- 15v on 2 of the pins i think the 2 on the bottom that are vertical from each other which i don't plan on using. Would this work or should i not do this?
thanks mr babin, from your experience if my rca is putting out 5v if i was to use balance line would my sound quality improve or it wouldn't make any noticable improvement?
I don't know. The speaker level outputs may be a bit noisier but you could reduce the gains so it may be better overall.
