Hi everyone,
I bought a new tube amp: "Soundmaster No.34" (Convergence Corporation No. 34 Sound master Tube Amps)
Does anyone have a schematic diagram?
I am new to tube amps and would like some help since I noticed that high frequencies disappear at high volume, but sounds good at low volume. Is this normal with tube amps?
Thanks in advance.
Thanks in advance.
Velleman, Inc. - International - Overview
Looks real similar if not a direct copy of.................
No. It could indicate that the volume control is too high a value so creating a low pass filter with the Miller capacitance of the next stage. This effect would be at its worst at -6dB volume - so nearly maximum assuming a log law pot.I am new to tube amps and would like some help since I noticed that high frequencies disappear at high volume, but sounds good at low volume. Is this normal with tube amps?
IceFyre13th: Thanks for your reply. The chassis looks nearly the same but not the same amp. Mine is only 2 ECC82 and 2 EL34 per channel.
Dear DF96, Mostly you are right.
But I can not confirm without having the schematic diagram. If I find one otherwise I would have to draw myself. Thanks a lot.
Pretty easy to confirm even without a schematic if the volume control pot resistance is anything greater than say 100K. A quick measurement or visual inspection should confirm. Even worse if there is an input LPF in the first stage right after the volume control.
