Sound Digital 3K Evo D1
Joined 2009
Hello everyone
I’m working with this SD 3K. Here is the problem with this amplifie. it came to me with a broken speaker connector
but after I resolder the connector I found out that the 10ohm resistor the is in series with a 470nf capacitor at the
output filter circuit was getting red hot, but if cheat the amplifier to come On without the rectifiers and use a 30 volts power supply
as a replacement for the rail voltage the 10 ohm resistor don’t get hot and the amp plays. any suggestions?
Thanks in advance.
