Going through some more stuff I will probably never use again, I found three of these little boards that delay your B+ for ~20-30seconds to allow your heaters to warm up. They are tied in with your heaters to run the IC and the relay.
I pulled the LED off one of them because it is kind of annoying, but all three worked fine when in use. Asking $55 shipped for all three in US.
Thanks,
Blair
Thanks,
Blair
Hi Tom,
Mounted off a side panel, on a standoff, they should work. Upright, they are about 1 7/8", but the short side of the board is just shy of 1.5".
Thanks,
Blair
Thanks,
Blair
