Hi!
I'm looking for some tweaks about Sony cd player XA2-ES.
Could you help me?
Best Regards.
Enzo.
Could you help me?
Best Regards.
Enzo.
1. Better transformer (torodial)
2. Better power supply capacitors e.g. Panasonic FC series
3. Faster diodes in the power supply e.g. IRF HFA08TB60
4. Better Opamps; depends on, what ops are used in this CD-player.
Hi!
The opamp used in my Cd player are NE5532P.
Some people advice me to change them with Burr Brown OPA2132.
What do you think about?
Best regards
Enzo.
Best regards
Enzo.
In my opinion, you should use an adaptor 2xSMD -> DIP8.
Very good audio ops are:
1. BB OPA627
2. AD825
In this case, a OPA2132 may be not the right choice, since it is an JFET input OP. The source impedance has to be <=2kOhm.
And have a closer look at the power regulation.
1. BB OPA627
2. AD825
Keruskerfuerst said:In my opinion, you should use an adaptor 2xSMD -> DIP8.
1. BB OPA627
2. AD825
JFETs have high input impedence, therefore can tolerate higher source impedence than bipolar transistors.
Keruskerfuerst said:But a FET has a non-constant input capacity.
The input capacitance of a typical JFET opams is only a few pf. Therefore, any nonlinear modulation is not likely to result in significant distortion in audio applications. This issue will be important for power FET (e.g., IRF240), which indeed needs a low-impedance source.
The distortion will increase by the factor of 5, if the source impedance is greater than 2kOhm.
You can measure and hear this.
Keruskerfuerst said:The distortion will increase by the factor of 5, if the source impedance is greater than 2kOhm.
There are many ways to use opamps incorrectly. I do not know what circuit you use around opamps so I cannot comment on your measurements. However, in general, when the input impedance for both the noninverting and inverting inputs are matched, the nonlinear modulation due to the JFET input capacitance becomes a common-mode signal and is rejected.
- Digital Source
- Sony XA2-ES Tweak.
