Hello,
Im a happy owner of a Sony TA-N80ES power amplifier. Recentry it started to go to protection just few minutes its powered on. I thought at first it was a bad speaker connection but it wasnt. Im trying to get the service manual or squematics to repair it. Do you think it worth to repair it or should i go and buy something else more actual?
thanks in advance
anonbeat
thanks in advance
anonbeat
HI, this kind of amp sure worth the repair.This a great amp, not very complicated to fix. Give it a try.
I'm sorry to kind-of-threadjack this, but..
I need the schematic/service manual for Sony TA-F700ES...
Sorry to but in.
Regards TroelsM
Sorry to but in.
Regards TroelsM
Only have manual for TAF-F333ESR and 703ES which should be very similar if not even equal.
You´ll get them if you name your email adress.
SOP
SOP
Hi SOP.
I would like a copy of that manual.
My email is: XXXXXX
Thanks!
Regards TroelsM
Edit: Mail-address removed. Thanks for the Manual!
My email is: XXXXXX
Thanks!
Regards TroelsM
Leolabs said:Hi anonbeat,try to check the DC offset voltage.
I guess i finally fixed it. I adjusted both... the DC offset trimers and the v bias trimmers. It was tricky to get the proper values as minor movement did difference but i did my best. Now its been testing it for more than a half without protection.
Thank all for replies and SOP for sending the service manual
greets
anonbeat
- Sony TA-N80ES
