I recently got out of storage; put on new power cord and cleaned the push button switches; the unit worked fine until it got a little warmed up then loud cracking static comes out of left channel which cannot be volume adjusted at all; comes through headset as well so not the speaker connection; what is this noise coming from. mj
Its after the volume control in one channel, probably a component on the left power amp section. Localizing intermittent problems can sometimes be done with a cool-spray or an insulated poking stick. Thermal or mechanical changes can affect the faulty part enabling it to be traced.
Are you happy/confident to work on the unit opened up and powered?
Anything mounted onto a heatsink, such as output transistors or regulators, and some power resistors, can have dry connections.
Over time, with the normal heating/cooling that happens, these become intermittent, and need to be touched up with fresh soldering.
