Sony scd-xb770 read problem.
I got an scd-xb770 sacd/cd player, that does not read almost any cds. I have tried to calibrate it (according to the service manual), but without success. Sometimes, if it succeeds to find a disc, it might play the whole disc without any problem. Some discs never work, and some (mostly cd-rs) work about half the times. Cant seem to find the proble, with this one. Does anyone have any ideas or suggestions?
Thank you!
Somebody suggested that some CD players had a wrongly adjusted inner stop for the laser which caused the failure to read the innermost track information and thereby the whole read would fail. This sounds like a plausible explanation since you are able to read a whole disc once it is found.
Do not know how to adjust it thogh, there was a thread here previously but i cannot remember what to search for to find it.
Hi, yes I tried cleaning the lens. I believe that my player will have to RIP. I have checked cables, and solderings, and resoldered suspicous things. I also asked the same questions on techniforum, and spoke to a guy from .cz who had worked 9 years at sony service. He recommended to try to freeze the laser, to see if it is the problem, and when i freezed it, it worked better for a while. Dont know where to go on now, dont think I will change the pickup, as this player isn´t that good in the first place, and the pickup is rather expensive (300e at sony service in finland).
Thank you for your suggestions.
