I have a Sony combo cd/stereo Model MHC-1600 / HCD-H1600 and I have a high pitch hum when I put it in the CD mode only.
Would anyone have any suggestions on the problem ?
Sony-MHC-1600 cd / High pitch Noise
Hi Chris,
The high pitch noise is only when you are playing a cd. You only get the noise without any audio. But the counter and tracks for forward and backward works just like it is playing a cd?
Thanks for any help.
Hi Chris,
Hi Rusty777,
If the noise is mechanical from the mechanism area, it is from the lense of the laser assy. Could be a servo is oscillating (gain too high). The servo's normally make a white noise type sound. You can't normally hear this.
If the noise comes from the speakers you may have a problem in the filter stage or servo noise may be getting into the audio. You need a 'scope to check further in this casse.
-Chris
-Chris
