Sony cx355 CD player "ticking"
Hi, I wonder if anyone can help with my problem.
The cx355 develops a ticking after a half hour or so of play. The CDs sound fine but a tick or click develops in the signal and is heard along with the music.
Would appreciate any advice
Very hard to diagnose, it could be several things... and its quite a complex machine for one thing.
If the tick is present on the audio output then it could be a mechanical problem causing the error correction to kick in and make its presence felt. The only way to check this is to monitor the RF signal and see if a glitch can be seen in the signal. It could even be something as simple as disc wobble due to a bit of contamination on the platter.
