Sony CDP-505 tracking adjustments, HELP!
I have a Sony CDP-C505, it works, but not all that well. A few CD's it will make ticking sounds on. It skips very very easily, even from vibrations from the speakers. I know that there are adjustments in the transport to improve tracking and current and all that. Does anybody know the specifics on my model? The transport has three seperate pots on it instead of the usual one...
Thanks in advance...
- Duo
Tracking
I suggest that you buy a book on CD player repair and diagnosis.
First of all, clean the lens with a Lens cleaner CD (available at most computer stores).
To get you started, most transports have 3 trimpots that adjust tracking/skipping:
Laser focus
Laser tracking
Laser gain (don't touch this one)
What I usually do is make a test cd: cut 1mm wide strips of black adhesive tape and stick them to underside of CD, as 4 spokes.
Make sure that the spokes do not cover the TOC area (inner rim), or the test CD will not play at all.
Mark with a transparency fine point marker the position of all the trimpot wipers.
Play the test CD or a CD that is not scratched but skips.
Adjust the laser Tracking trimpot first to the left, until the CDP fails. Mark thet spot with a red dot. Return trimpot to original position.
Play CD and adjust trimpot to the right until CDP skips or stops. Mark that spot with a red dot.
Now position the trimpot wiper exactly between the 2 red dots.
Play the CD, if it still skips, adjust the laser focus trimpot following the same procedure.
You'll need a plastic screwdriver (used to align FM tuners).
If the Tracking and Focus adjustments don't fix it, your laser is near the end of its life. Turn the laser gain trimpot clockwise just enough to read the test disc and a few scratched Cds. Expect the laser to fail soon, this is just a temporary fix while you get a new laser unit (like biasing a weak tube).
I hope this helps.
BTW this may seem very non-scientific, but I swear I learned this technique with IBM, to adjust tracking of mainframe disk drives. Of course the test disk was different (but coincidentally we looked for a fish-eye pattern on the scope).
Good luck
Simplified test
Hi Carlos,
Thanks for your suggestions. I have a defective CD67 which might be fixable. Sometimes these kinds of solutions will be much faster than finding and looking into a service manual.
Thanks for reminding us of the simpler ' not so technical' solutions!
Cheers.
Precautions
Duo, as a precaution note the position of all the three pots so that you can go back to the original position if you goofed.
Another method is to measure the resistance of the pot with a digital multimeter when the system is OFF. Measure it after at least 10 to 15 minutes after switch off so that all internal voltages drop to zero. Measure between slider and one end of the pot.
This makes it much easier to get back accurately to where you started. Note down all measurements with pot number "in a book". Preferably a book that will not get lost easily! Never on pieces of paper which always seem to disappear. As you will see in other posts on the forum , you are really lost if you can't get back to where you started.
Cheers.
I've Replaced Many Hundreds Of These.
KSS-240A pickups have the photocell preamps inbuilt, and are not really adjustable.
Also they are (un)reasonably unreliable and failure prone, and this sort of failure is quite common.
There are no adjustments required, so the only course of action is to replace it, and you can do this yourself.
Also the ribbon connecting cables fatigue and become unreliable, so best to replace this first or together with the pickup.
Eric.
Well... This pickup does have adjustments on it. Three to be exact, as I stated earlier.
The pickup still works but it is extremely susceptible to outside disturbance. Many times it has simply quit playing in the middle of a song and sits there trying to focus like mad and making clicking noises until I turn the CDP off completely to start again.
A potential problem with Sony pickups is a sagging suspension. Play the unit upside down and if that works replace the pick up. Somtimes the pickup can be restored by heating in an oven (upsidedown) for a few minutes and allowing to cool down slowly.
I would replace the pickup, less hassle.
Jam
