Sonotube Dist.s (A long shot, admittedly)
Home depot
Your average Home Depot has sonotube in sizes that would be of use in residential sizes
And construction material suppliers to those that deal with concrete have larger sizes that might be used with say a bridge.
regards
Ken L
not only that, but because Home Depot ( or Lowes whatever) has certian sizes, which are generally small, if you find an expierienced employee they'll tell you where you can get odd sizes of tubes at a construction provider. I bought 4 tubes for 12 to the radius of 12 niches that i wanted. The advantage wasnt just the availability of the radius, but that they cut it right there to the length you need!
Brian
Way too big, thanks anyway delwon. I'm working on an HT using 5.25's in t-lines (Cannon for the sub, which will probably require a lot of experimentation; hence, the cheap tubing).
Would you believe, I'm having trouble locating a building supplier that carries this stuff?!?
Terribly irritatin', doncha know, I'm on a tight schedule for this system......
Thanks for the tip, btw
