Sonodyne SA5000
Most common output of 3055 & rail voltage is obviously 40v. Op-amp is MC1458. The set is tampered by some unskilled. The R C s changed as per his wish. So schematic is required to set at right. If you have or may be arranged that would be a great help.
See, the amp section is a 40V implementation of the 2N3055 circuit, so the values used by Sonodyne and others will be similar, at least enough to start.
The pre-amp / selector section, again the IC is common, you can find the data sheet and start from application note provided.
This will improve your chances of repair to a large extent.
Power section is now ok as I think after rebuilding. Pre-amp section specially associated components around MC1458 are to be matched on trail on error basis. Because the values as per datasheet are not matching. So I prefer to get a original schematic to make it easier. On the PCB many long wire jumpers are used as I noticed.
