Some suggestions for my tiny speaker project
Hello all. I'm in the process of making a pair of spherical speakers with size and price as the first priorities.
The enclosure are these tiny balls that picked from a thrift store for 1 euro:
Their diameters are around 10cm. My idea is to cut out a small section and mount a full range driver there, eventually having a speaker that looks like an eye-ball :happy1:
With that in mind, I have couple questions and I appreciate your feedback:
  1. What driver do you suggest? I think it should not be anything larger than a 2~2.5 inches. Ideally, I like it to have a rounded edge (unlike e.g., TC7FD00-04 that has a squared frame). But I'm willing to compromise here for better sound quality.
  2. Speaking of sound, I don't thank it makes sense to have a port, or am I wrong? I'm not experience at all and I just have a gut feeling to fill the enclosure with sound dampening material. Any suggestions about the enclosure?
I want to keep this a cheap built and prefer not to pay more than 15 euros-ish per driver.
If it matters, I don't really care about high SPL or laud bass. Instead I prefer to have something flat-ish and a clean response (I have no illusion that such an enclosure and cheap drivers will get me nowhere in terms of sound fidelity. But between the SPL/Laud and flat I prefer the latter...)
Thanks a lot for any feedback.
P.
what volume do you think those enclosures will provide?
if it is around 0.01cuft each you could try a viston BF37, but be warned it is a bit low on the sensitivity and is actually a 1.5 inch full range. You can also get them a digikey and places like that for a decent price.
Other option could be a Dayton Audio ND65, they actually measure 2 inches and seem to operate quite nicely in around 0.04cuft
if you could get to the back, you could rear mount it and hide the frame.
Thanks a lot for the response 3rutu5.
It is indeed 0.01 cuft. Being in Germany, Visaton is actually quite affordable for me (compared to ND64: 10 euros vs 30).
Based on this choice, which variant to you think is better? 4 or 8 ohm?
Considering the size and the shape of the enclosure, do you think I need consider baffle step compensation?
