Some diyAudio polls from the past
Moderator
Joined 2008
About 10 years ago for a short time this site was set to display random polls from current threads, on the home page. As a curiosity, these have been harvested from the wayback machine.
What's your next project?
Source - 7.47% 18 Votes
Preamp - 20.75% 50 Votes
Amplifier - 42.32% 102 Votes
Loudspeaker - 24.90% 60 Votes
Other - 4.56% 11 Votes
Do You Think Single-Ended Class-A Amplifiers Sound Best?
YES! - 40.45% 108 Votes
NO! - 19.10% 51 Votes
Nothing Special. Just Another Amplifier. - 22.10% 59 Votes
I Haven't Seen Such An Amplifier. - 18.35%
Cat or Dog, Tubes or Sand?
Tubes + Cat - 23.81% 35 Votes
Tubes + Dog - 18.37% 27 Votes
Sand + Cat - 27.89% 41 Votes
Sand + Dog - 18.37% 27 Votes
Other (be nice to us and tell) - 11.56% 17 Votes
Have i lost it or is it good?
You've got it totally wrong - 50.00% 2 Votes
You're overlooking other important things so it'd have no effect - 50.00% 2 Votes
There is cleverness in it, but you're not quite there yet - 50.00% 2 Votes
All hail the messiah of audio fidelity! - 75.00%
well, do MC carts sound better than MM ones?
yep - 70.77% 46 Votes
nope - 29.23% 19 Votes
Most neutral/least audible crossover topology?
B3 - 15.38% 2 Votes
LR4 - 7.69% 1 Vote
B5 - 0% 0 Votes
LR6 - 0% 0 Votes
B7 - 0% 0 Votes
LR8 - 0% 0 Votes
LR2 - 23.08% 3 Votes
none of the above - 53.85%
Colour of the pcb
Red, white print and gold pads - 20.00% 4 Votes
Blue, white print and gold pads - 20.00% 4 Votes
Black, white print and gold pads - 30.00% 6 Votes
Black, yellow print and gold pads - 0% 0 Votes
Yellow, black print and gold pads - 0% 0 Votes
Green, white print and gold pads - 25.00% 5 Votes
White, black print and gold pads - 20.00% 4 Votes
White, red print and gold pads - 0% 0 Votes
What's the highest frequency you can hear?
Up to 21kHz - 1.43% 1 Vote
Up to 20kHz - 0% 0 Votes
Up to 19kHz - 4.29% 3 Votes
Up to 18kHz - 17.14% 12 Votes
Up to 17kHz - 20.00% 14 Votes
Up to 16kHz - 22.86% 16 Votes
Up to 15kHz - 11.43% 8 Votes
Up to 14kHz - 12.86% 9 Votes
Up to 13kHz - 2.86% 2 Votes
Up to 12kHz - 7.14% 5 Votes
Will MJL21193's crazy design work as proposed?
Yes - 49.30% 35 Votes
No - 8.45% 6 Votes
Maybe. - 29.58% 21 Votes
I'll laugh when it doesn't. - 12.68%
What cabinet should jlux use?
Del Sol -Aura NS3 design - 5.26% 1 Vote
Milli Fonken - 10.53% 2 Votes
RS100 Transmission design - 26.32% 5 Votes
HEY- The best choice is none of these!!! - 57.89% 11 Votes
To Glue or not to Glue, that is the question.
1 - Glue the covers on at the Factory. - 0% 0 Votes
2 - Leave loose, let end users choose to use or discard cover. - 87.50% 35 Votes
3 - Offer both glued and loose cover options. - 12.50% 5 Votes
