Hi All
I have a Roland 80017A chip that has lost one of its legas and solder pad that the leg solbers onto
Can i use a conductive paint (suspended aluminium particles, Bare Paint or any other kind of paste/solution to cure this
Cheers all
V
Cheers all
V
Well a search tells me the IC is a single in line special. When you say its lost a pin do you mean its snapped off near the package ? Even if it has I bet you could solder a single strand of wire to whatever is left of the old lead, even if its flush with the package. Then put a tiny dab of epoxy over the connection and run the strand of wire through the PCB hole and scrape and solder to the print it connected to.
I wouldn't think conductive paint a good solution tbh from what you describe.
I would follow Mooly's procedure, but I would first use an Exacto to remove some of the plastic from around the broken pin. You don't need much, and can probably get ~1mm cleared without destroying the package integrity. Then run the wire to the former pad connection. ("Solder pad" doesn't confirm whether this is through-hole or SMT.)
Aren't there conductive epoxies out there? Not that you would solder to it, but rather 'glue' the joint back together...
Yes there are conductive Epoxy's, But the last one I used was so thick I could barely get it out of the squeeze tube.
I still have it but it is a solid rock now!! He,he,he
You can try gluing the end of a piece of wire-wrap wire using some conductive paint and solder the other end were it needs to go.
I have used this method a few times and it works well.
Here is one such instance,
http://www.diyaudio.com/forums/planars-exotics/196631-apogee-speakers-construction.html#post3409337
That one was done using a Silver Paint pen in 2002.
Another time (buried in these threads) I I used some Nickel print and also a rear window defogger repair kit ( copper paint) to make a connection to a broken off of a Aluminium wire mesh tab on my DIY Esl.
Both are still holding and still working to this day.
jer 🙂
jer 🙂
Broken legs are a real problem with the poor design of these chips.
There is a solution, See;
80017A VCF VCA JUNO-106 VOICE CHIP FILTER IC REPLACEMENT
Hope this helps
Hope this helps
- Design & Build
- Construction Tips
- Soldering onto conductive paint
