Solder mask
Hi all
I've got a question - what is easy and elegant way to make solder mask on PCB - is there special kind of paint or lacquer (in spray probably :scratch: )? Did somebody of you make mask by himself - if yes what technique?
I suppose I can use common paint but it won't be transparent :dead: and I'm not sure that it would be durable e.g. high temperature :devilr: during soldering.
I use urethane spray (Techspray) but it is reworkable. It still helps keep the traces on the board and keep the solder where it is supposed to be.
I believe there is a non-reworkable silicon spray but I have never used it.
I have used those little soldermask pens...they work great, but cost an arm and a leg...
