These things suck the pins are so close togeather, Im using electronic solder and half of the time it dosent even stick to the pins or wire it just lays on top, Or I accidently fill in the tiny hole your supposed to put the wire end into or God forbid the Solder falls in between the pins and then 2 are connected. am I doing something wrong? I seriously need to order some Online cause I mess every other one up( throw it againsed the wall and scream 4 letter words and such) any Ideas????????????????
first you have to clean the pins ( old solder)
may be use some soldering paste or flux
i think you are using poor quality solder
the best is mixed with sterling it does a very bright solder and its more liquid when hot
put some solder on the pins and on the wire end
then heat the pin and put the wire end in, it's done
don't put the wire end it the pin and the solder after on it
it doesn't work
sorry my technical english stinks
bye
it doesn't work
bye
