Hey all,
Do I need a Soft start on a SMPS?
I have read a while back about never using a Variac to ramp up power on a SMPS (is this true?), so I though same thing would apply with a soft start on a SMPS...
Its a Icepower ASC1000 amp. Currently do NOT have a soft start.
Thanks all in advance.
Is possible to modulate the pulse of the controller with a capacitor to ground, but i don't remember wich pin. Let me make a couple of calls in these days.
Soft start
If I understand what you want, I think you need a soft start circuit in SMPS, Specially to protect from the INRUSH currents at startup.
You can do that in SG3525, But dont know your circuit!
Fox 🙂
Fox 🙂
On Pass class A amps they use a CL-60 thermistor on the primary to tranny.
Can I use one on the Mains input to a ICEpower ASC1000 (has an internal SMPS)
Actually, after further reviewing the manual, it offers 450ms power supply start up delay, and another 1200ms on switch start up delay.
Never mind. Its good as is. This is the easiest amp I have ever built.
On SMPSs, Soft-Start is most always done at the PWM Controller IC. For the SG1525, this is pin-8. Connect anything from 0.1uF to 10uF to ge the desired time-constant. For the MC33025, this is also pin-8. For the SG1846,. there is no dedicated SS pin, but you would connect the COMP pin to a buffered SS ckt. For the TL494, an RC combo with the Cap from V+ to the deadtime (pin4) and a resistor from pin 4 to ground will accompolish SoftStart.
Hope this helps,
Steve
Hope this helps,
Steve
