socket mounting depth
I recieved all my parts for my first tube amp , however being a tenderfoot I jumped the gun and ordered a t6061 aluminum chasis that is .160 " Thats right that is no misprint. The OPT(2) is the monster hammond 1627se. The 2a3 sockets are Azuma 4 pin 2/32 " in depth.
needless to say when mounted underneath they are far from the being flush. Besides top mounting any advice? should I get a different chasis > I was never realy sure what a good gauge chasis would be .
tenderfoot
These imperial measurements are confusing me... :xeye:
As long as the chassis can hold up all the things on top of it reliably, it shouldn't be a problem. Provided the connections can be made, how the sockets are mounted is simply a matter of aestehetics - it is neatest when flush mounted.
tenderland said:
...I jumped the gun and ordered a t6061 aluminum chasis that is .160 " ...The OPT(2) is the monster hammond 1627se...
tenderfoot
Tenderfoot,
The only issue is one of aesthetics. If you are happy with the way the sockets look there isn't any technical problem with them not being flush.
If you are not happy with the look you have a couple of choices. First you could grind down the underside of the socket holes as wide as the socket flange (sort of recessing it in reverse to make it flush). The kind of thing is probably best done with a milling machine. Second you could top-mount your sockets (but you may like that look even less). Last you could get a different thickness of aluminum for the top-plate.
I just built a pair of monoblocks using .125" (1/8") 6061 aluminum and the octal sockets I used mounted flush. The strength of 6061 is such that for my chassis size (12" x 12") I could easily stand on it without bending it.
chasis
Thanks , I can use a die grinder to shallow the chasis a bit , one major negative is I dont think I can easily use chassis punches for socket holes. I know you can drill holes inside the circumference and than use the punches , but this is a pain.
Re: chasis
I used bimetal hole saws to drill the larger holes in my chassis and a step drill for most of the smaller ones. Both worked very well in my drill press. I used 1 1/16, 2" and 2.5" hole saws.
I had to drill one 2" hole with a handheld drill because the "reach" of my drill press was a little short. I drilled a 1/8" pilot hole then put on the 2" hole saw and drilled the big hole. It was surprisingly easy (I used a cordless drill) and the hole ended up round!
drill
Good info, I still remember our discusion about running the B+ and heater wires together, I am prototyping now and found that I was shipped 1 incorect cap for powersuply. I would like to do some noise measurements on 2 different chassis configurations and running wires together.
may I ask where you guys are getting these Al chassis'? Custom made? Cause I can't find anything near that thick. I got a hammond one that is very thin and has cheap spot welded corners. Its kinda dicey for a 60 lb. amp. Maybe I'll take up mig welding.
I have purchased a couple from eBay that were pre-cut to the size I wanted and the price was not too bad. You can also cut aluminum plate on a table saw or bandsaw. (Wear hearing and eye protection!) Keep in mind these aren't really chassis but simple aluminum plates. You have to make some type of base yourself.
Also there are lots of different alloys of aluminum and even at 1/8" some might not be strong enough to hold a 60 lb amp without additional support. 6061 aluminum is incredibly strong so if you have a choice I can recommend that one from experience.
You might also try to find a local metal shop. There used to be one that would sell me their "cutoffs" pretty cheap and if they weren't busy they would cut it to size for me though they usually charged me a couple bucks per plate to do that.
