Now I'm wondering...how do I tell what this thing
https://smile.amazon.com/gp/product/B07R47RYPW
is actually capturing? The idea was to-in the absence of a storage oscilloscope-use the peak hold function to determine if an AVR is clipping.* But now I wonder how fast is it, is it really getting the peak of the peaks.
*by calculating the voltage rail from the all-channel power spec and comparing. If well below, not likely clipping. If well above, clipping. If near, gee try to borrow a storage scope...
Or build something like that:
https://www.diyaudio.com/community/...age-and-current-detector.276985/#post-4523999
"the manual is incomplete and poorly translated (annoyingly so)."Look for information in your DMM manual
"Good DMM. Terrible user's manual. The user's manual was obviously written by someone for whom English is a second language. So bad could not figure out how to do simple measurements like resistance. Web site which is thsinde.com.cn ..no longer is available."
Yes; or even simpler. A 1N400x diode and a 0.1uFd cap, plus maybe a 10r 1W resistor, to any cheap DMM, will "determine if an AVR is clipping." The 0.6V error is insignificant on typical 30V peaks; or can be fudged-in. Unless you only listen to male announcers, raw, peak is as good as peak-peak since most speech/music is near symmetrical to a dB.Or build something like that:
