SMPS for DIY Audio F5c
Joined 2011
I am planning to build an F5c with the newly announced DIY Audio chassis.
I already have my input FET's and will be placing my parts order soon.
I am planning on paralleled output FET's and cascoded input FET's
I originally figured on using a CRC power supply for this project but now I am wondering about a SMPS.
What should I look for?
Any suggestions about a good manufacturer or specs I need?
Thanks,
I haven't tried it on the F5 for lack of time. In general, I think they are
workable, especially if you give them some passive filtering. Often this is
a problem as the start-up circuits of many SMPS sense the filter capacitance
as a short on startup.
The big deal with these things is that they work with switching behaviour. This is something like a high voltage high current transient. This transient will send high speed load source and sink currents down the line to your amp. It will be reduced by the time it gets there due to R and C and L on the way to your amp, but also, the amp won't actually be abble to get a clean transient and will likely sag momentarily. You can get something that won't, but, I guess that was the suggestion, to get something bigger than you need. There are levels of transient response performance that can be had. I work with Intel based processor SMPs and we test with 100k-1M square wave loads per Intel spec. At over 100A!
But, there is much more to it. those big switching transients cause gobs of High freq and RF noise on the Rail. Yes, passive filters can smooth that. But, the supply itself will radiate RF EMI etc. etc. it will generate noise back into the mains if not built correctly and screw up your pre, your source, and anything else close to the same mains wire. It will radiate between component cases and across you interconnects etc. etc.
Having said that, and scared everyone away. Make sure the suupply is a couple feet .5M away from any audio interconnect or circuitry. Use Highspeed Polystirene or Polyprop or goood caps in your filter...
Actually, half the equipment and appliances in your home probably have SMPs supplies in them that are messing up your mains now 😱
Supposedly the Vicor brand smps are supposed to be really good. They go for about $500, but can be routinely had for $50 on eBay. With the "ripple attenuator module" supposedly ripple down to 4mv. I haven't used them in an amp yet, so just passing info along. Worth a look.
