SME 312S and EMT cartridge
If you can remove the bottom cover of the EMT headshell,check if the cartridge wires on the headshell end have tags or are directly soldered on the headshell pins.If they have tags(female)then there is I guess no problem to fit the cartridge on the 312 arm after you remove the SME's headshell wire..That of cource if the other end of the EMT wires are connected some way on the cartridge too.
