What is the magig behind Creative Sub-woofers?
They are small, Use 4" or 6" Drivers yet create quite an impression!
These days you do find small subs producing big bass.
Is it the Drivers, the enclosures or the electronic equalisation?
bimbla.
bimbla.
Do you mean the subs on Creative Labs computer speakers?
I don't think they are very special at all. I've found that when I turn them up they stop producing good bass and just start making farting sounds.
Small drivers do not go as low as other types of subwoofers, but in many cases one does see tighter response from the drivers which are smaller and can move faster. It also depends heavily on the enclosure.
One example of a low-frequency unit that uses small woofers is the Bose Acoustimass. (I know Bose is not highly-regarded at all but it's just an example, OK?) The older Acoustimass modules that used an 8th-order Bandpass enclosure had very flabby bass. On the other hand, the ones they distribute with the Lifestyle 28 and 35 have a sort of Transmission Line enclosure and their bass is a lot more tight and better-defined. They also use higher-excursion woofers so they can move enough air to go lower than previous Acoustimass modules.
It's a combination of all three factors really. New drivers are beinging designed to have larger Xmax figures, most computer subs use bandpass boxes to boost efficiency and I'm sure that all use equalisation too.
The problem is that a small driver in a small box will never play deep bass loudly - Hoffman's iron law sees to that. Just try increasing the volume and you'll soon hear it distorting as the driver runs out of excursion (assuming the chuffing from the bandpass port doesn't become objectionable first!).
Nice one,
David.
Nice one,
David.
Small Subs
No wonder, these days there is only a master volume control and pre-set equalisers. No seperate Bass and Treble control.......The speakers do run out of breath soon like both of you said. Thanks.
bimbla.
bimbla.
Though I was surprised when I went to the Best Buy and started turning up the volume on their Lifestyle 28 system. I would have expected a Bose system to lose control of its BMs at those high volumes (customers passing by were wondering what the heck I was doing) but the bass module and speakers still kept playing the same-quality sound even at very high volumes. Certainly uncharacteristic for an Acoustimass system.
bass limiter filter
Hello
Do any of you know how to use a subbass filter to limit how low of bass a speaker can produce. I think this will lessen my chances of damaging my woofers.
Thanks,
Opie
Hello
Thanks,
Opie
Check out this site http://www.dansdata.com/speakersets.htm
One creative labs product even use passive radiator design for its sub.
I have made a little subwoofer with passive radiator with little sucess. It sounds ok in small room / car if I don't crank up the volume too much. Isobaric the woofer make the power handling better. The Xmax just not enough...
- Small Subwoofers
