hi
I need someone to help me out.I want to create a giber file for a small board i have
about 1 inch x 3/8 .It only have five components .Any one interested i can send you pics
If it's truly THAT simple, post a schematic and photo, plus the details of what your PWB fabricator expects to find in the Gerber files.
Dale
Dale
material:fr4?
copper thickness:
board thickness
solder mask: green or blue
component hole size
board size
You might have better luck doing what I did...
You can download and use Eagle PCB Software for free (max 2 layers, 100x80mm):
Download - Get the latest Version of EAGLE PCB Design Software
Sparkfun have a very good Tutorial for getting started:
https://learn.sparkfun.com/tutorials/using-eagle-schematic
You can the have it printed by OSH Park, who charge "$5 per square inch, which includes three copies of your design. For example, a 2 square inch board would cost $10 and you’d get three copies of your board. You can order as many copies as you want, as long as they’re in multiples of three."
OSH Park ~ Welcome
I'm very happy with the results 🙂 Here's a board I made using them (OSH Park only made the board. I had to solder the components on myself):
OSH Park ~ Welcome
OSH Park ~ Welcome
Thanks for the link. I like their pricing policy.
I have used OSH Park many times - the quality and speed are top notch. They take the raw Eagle board file, you don't even have to create Gerbers. And they come in the cool purple and gold color scheme.
I also use Fusion PCB (Seeed Studio Bazaar,Boost ideas,extend the reach - Fusion PCB). For anything under 5cm x 5cm it is about $10 for 10 boards plus shipping, with increasing pricing for increasing sizes. If you order more than 10, the price per board drops.
- Design & Build
- Construction Tips
- small project board
