I am looking for a driver that is the same size as or smaller than 6.5" that has dual voice coils. I know Monacor makes one, but I don't have any idea where to buy one. This is to make a bass module for a pair of Tangband W3 drivers.
I want to build one of those pant-flapper transmission lines with one.
Parts Express has a Goldwood 6.5" DVC "subwoofer", although its ultra-high Qes limits it applicability.
http://www.partsexpress.com/pe/show...20&St3=31722923&DS_ID=3&Product_ID=7559&DID=7
Here is the Monacor Contact page from their website, if it comes to that:
http://www.monacor.com/index.cfm?PR...=1&private_iAktuellerNode_MenuRoot=815&STYLE=[default]&PRIVATE_IAKTUELLERNODE_LEFTMENUBOTTOM=837&PRIVATE_IAKTUELLERNODE_LEFTMENUTOP=830&PRIVATE_IAKTUELLERNODE_RIGHTMENU=817&Caller=AT&CS=24D5D540F18B74345F4F9BF27741D832
And here is their contact info:
Phone: (0421) 48 65-0
Fax: (0421) 48 84 -15/-16
E-mail: <mailto:info@monacor.de>
Their contact page listed distributors from several countries-none in the Western Hemisphere. But contact them anyway-you know how these companies are about updating their webpages. There might be somebody in the USA carrying them and the webpage hasn't listed them yet.
If you want to pay 80 bucks, there is the Focal 7V4211DB, available at Speaker City.
http://www.speakercity.com/focal/focal_midbass.shtml
Audax mentions two 6.5 inchers-the HM170ZO and the HT170G8.
Parts Express seems to have some kind of kit with the HM170ZO, but the kit mentions nothing about dual voice coil!
Also it was supposed to be replaced by the HM170Z18, but again there is no mention of dual voice coil in the new model.
Anyway, here is the Audax spec sheet. Check it out for yourself.
http://www.audax.com/bin/specsearch.pl
The HM 170ZO has an especially nice feature in that the Qes is .37, the Qts is .35, and the Fs is 35. Nice and low.
I am sure there are other 6.5 dual voice coil woofers. Keep looking.
Of course, if you need a dual voice coil woofer because you plan on hookng it up to 2 channels, I would point out that two 5 inch speakers have the same cone area as one 6.5 incher and you can hook each 5 incher up to a different channel.
Oops, my mistake. The woofer I was referring to was the Audax HM170Z2, not the Hm170Z0. My mistake.
That Audax link I gave doesn't work. Try this.
Go to www.audax.com
Click on "Products"
In "Woofers" section, click on arrow at the right of the slot which says "Driver size"
Select "6.5". Then click "Submit".
Specs for all Audax 6.5" woofers will appear.
In "Z" listing, the HM170Z2 and the HT170G8 will have listings of "2 X 8"
Go to www.audax.com
Click on "Products"
Since i just scored some Tagband 3" i've been thinking about this too. I think i'm going to try a number of drivers on the bottom. With the exotic cast-basket ones i'm going to try my Jordan JX150, and for a dual voice coil 6 1/2 i'll just use pairs of the PB/VIFA P17s i have a case of.
Give a pair of 6 1/2s consideration instead of one with 2 coils.
dave
dave
One thing you can do with dual voice coil woofers is
build some serious motional feedback.
Any interest?
Any interest?
Any interest?
Yup, Nelson, but as I have only just worked out how a Gainclone works, it could take some time...😀 😀 😀
Nelson Pass said:One thing you can do with dual voice coil woofers is
hmmmm... i wonder if you could add emotional feedback 😀
dave
Re: maybe OFS but..
I'm still thinking on these. I have the exotic ones (i will start a whole new thread on these -- from just a cosmetics point-of-view they are gorgeous -- hopefully they sound half as good). I'll match these with some nice woofs -- i have a set of Jordan JX-150s and a case of PSB/VIFA P17s (i'll be surprised if the 3" keep up with the Jordans, but i'll have then in a box at least). This will have to be active since the woofers are more effieicient than the 3s.
I'll do something similar with the cheaper ones, but use either a set of 4 Adire AV3s or RS 40-1022s i have. I'm leaning to the AV3s since they are shielded and in concept this would be somewhat like the elfs, but a true 2-way.
I will also probably play with adding a tweeter. Because the XO can be high and the 3s are extended this is ideal for 1st orders series play.
dave
swirv said:What do you have planed for those TB's Dave?
dave
planet10s Tagbands
You can help decide...
As promised i have pictures of the TBs i scored. I have started a new thread on these;
http://www.diyaudio.com/forums/showthread.php?s=&threadid=8054
dave
dave
- Small dual-voice-coil woofers
