small 2 way help?
I am looking to build a set of speakers for my system.
My system is:
Arcam CD73
tube pre with 6H30 (currently)
tube amps with PP 6B4G's.
cat5 and belden cables.
I like ALL types of music. I want a set of speakers that are small using very good drivers... that have high sensitivity... so that maybe a 2.5 way system.
Very good phase and impulse response is a must.. so is time alignment.
Thinking of building an enclosure of laminated MDF.. i.e. layed together and glued...
question is what drivers??? maybe Morel tweeter.. Eton mid?
6.5" or 5 1/4" ???
I am looking for something that produces a natural female voice... but also has detail and top end "air". Something that is quick to respond.
bass below 60-70 doesn't matter.... but would be nice.
any thoughts???
TIA!
Don't have a clue, I'm not into typical cone/dome speakers. About all I can say is that a typical two way design of low-medium efficiency drivers can't come nearly as close to meeting your stated performance goals as the Lowther/Fostex combo.
GM
single driver fullrange.
ok.
I think I will go down the path of single driver. question is which one???
I would LIKE a pair of Coral beta 8's. but to begin with should I buy those or use something a little cheaper?
either a TQWP or rear loaded horn.
looking at Fostex also.
