.slb file (translated library file)...!
hi.
OK. I looked into the help section.
for the ".slb" extension, it talks about translated library. what is a translated library?
this is the full text from help:
"If you use a part in a translated library and the library is not in the same directory as your design, you will not be able to descend (???). As a workaround, you can edit the part in the library and clear the name of the library from the implementation cell so that it is blank."
could anyone please give some hints in that?
thank you.
