hi,
you can use a L200 which is a regulator with current limit included.
you should charge your battery at 1/10 of it's nominal current.
you have to set the L200 to output 6.9v when the current limit haven't been reached.
Also check out the UC3906, made by TI (originally by Unitrode).
http://focus.ti.com/docs/prod/folders/print/uc3906.html
The Application Notes for this device provide a lot of information about how to properly maintain lead-acid batteries.
