I had a question about my 21" if the larger box is better. My answer soon became 'dual 18s > single 21'. I figured I'd post it here to see your input.
I just copied and pasted my reply:
The larger box does preform well, but be honest for the price of one MCM 21", you could get 2 MCM 18"s or this other 18".
Lets do a little math:
The Sd of the 21" = 0.1706 m^2
The Sd of the both 18's = 0.1232 m^2
Xmax of the 21" = 7mm
Xmax of the 55-2954 18" = 4mm
Xmax of the 55-2964 18" = 6mm
We'll double the Xmax to show the max air the driver can move linearly:
1x 21": (0.1706 (m^2)) * 14 mm = 2.39 liters
2x 55-2954 18"s: 2 * ((0.1232 (m^2)) * 8 mm) = 1.97 liters
2x 55-2964 18"s: 2 * ((0.1232 (m^2)) * 12 mm) = 2.96 liters
If we go by air movement the 55-2964 (Other 18") 'wins'.
Now the best way to find out is to put them next to each other:
Sadly I have the dual 18's taken apart right now. The 18's in the picture are the cheaper MCM 18's. I did give them a quick test out there, the dual 18's were louder, but they are in half space.
Here's the SPL curves of them:
Single 21" (55-2985):
Dual 18" (55-2954):
Dual 18" (55-2964):
Dual 18" (55-2954):
Dual 18" (55-2964):
I've had the question the question, "Is having two 18's better than one 21?" in my head for almost 2 years. I've been leaning to one side and then to the other, never able to make up my mind. Well I fixed that 18", and now answered the question. Even though the 21" will move 2.39 liters, and the dual 18's will only move 1.97 liters, the dual 18's are still louder.
well i know it is stupid to say one speaker is better simply because of it's size, since sound quality differences ever occur.
but the reason why i decided to post & say something is to point out the 4 inch voice coil on the 18 as the same size coil on the 21 inch
more voice coil surface area can be helpful if it is utilized.
**edit**
it also says the magnet is the same size?
well it says 100oz for both, but it doesn't say how strong the magnetic field is .. it says the larger speaker has 500 more watts RMS .. and i figure that amounts to inefficiency of the magnet in relation to the same voice coil size and magnet weight? .
**edit**
Now that I posted this, I'm going to try and fix the dual 18's so I can test this. One of the 18's were blown when my friend had them in his car, he gave them clipped signals
. The subs are his anyways, and hes ordering a new cone.
I just have them to install the new cone.
It will be difficult to get the blown one working, but its possible:
**edit**
Actually the magnate on the cheaper 18" and the 21" are both 125 oz, MCM has an error. As for power rating that 800W has to be peak, Its about 300-400w RMS. I gave it 600w and it started burning.
According to the specs the calculated BL would be:
55-2954 18": 35 Tm...?
55-2965 18": 20 Tm
55-2985 21": 24 Tm
sound quality aside..
i think the difference in cone size does a lot with the localization of the sound.
for example,
i've got some 5.25 inch midranges and i had some 6.5 speakers, so i decided to hook one up and hear how it sounded.
well the larger cone size certainly made it's presence known .. but i don't think i'm being totally fair because the 5.25 is rated for 75 watts rms and the 6.5 speakers are stock door speakers from a vehicle and i assume they are 30 watts rms
when i first hooked them up they weren't much louder in decibel or amplitude, but the radiated output matched the increase in cone size.
it made me think the 6.5 inches for a midrange that close to the listening position is simply too much, even if the woofer is 12 inches
and while midranges might not be as clearly viewed as subwoofers..
looking at the situation of the subwoofer isn't all too difficult.
the cone outputs, the room's boundarys interact with the output.. unless you are using them outside, because that is one place where i can't imagine smaller size would be helpful.
when outside, it helps to use a bigger cone with the hope of pushing on some air.. then grabbing that air and pulling it backwards, only to shove some more air into the pocket of air grabbed as if to create a slapping of air in front of the cone that is audible .. because doing that can help the amplitude of the small details normally perceived as clarity that would otherwise be lost in the air as it travels far away from the cone.
but that is why there is a difference between PA speakers and regular speakers.
you might say PA speakers aim their focus to cast out a soundwave as far as it will go, but in reality it doesn't serve a stable purpose because nobody knows the size of the room where the equipment is setup.. and the differences in size can prove to be really big.
which brings it back to grabbing of the air in front of the cone to make as much use of it as it can before it creeps away.
even if you use the sub in the house facing a wall, there are going to be different sizes in the rings expanding from the wall no matter if the same test tone is playing.
it is the size of those rings that travel throughout the room that can help answer why one size is more appropriate than the other.
for example,
one example for subwoofer size that i know works..
a 6.5 inch subwoofer that is very rich and muddy sounding.. it can bring the feeling of 'too loud' faster than my two 12 inch woofers.
but listening to the soundwave rise and fall, i can still tell the cone is only 6.5 inches
yes the small sub sounds comparable to a 500 watt halogen bulb on the floor compared to two 50 watt bulbs on each side of the room
but with the light and shadows in place, you can literally see the localization differences.
**edit**
oh, and when the two 12's add up to more lower extension than the small subwoofer.. it is hardly a comparison that i think the two 50 watt bulbs with their better localization wins hands down.
**edit**
anwaypasible, I agree with what you're about the sound localization, it does matter what you are going for. For home theater you want to know where the sound is coming from, hence 2.1, 5.1, 7.1, ect. For concerts you dont need that clarity of sound, like you said, you just need the sound to be coming form the front.
As for the the bass extension, typically the large the cone/Xmax the lower you can go for any speaker.
spl
Hi there a: Looking at your posted SPL curves:
21" (2985) at lowest note on a piano 27hz 88db
2x18(2954) " 27hz 85db
2x18(2964) " 27hz 88db
21" (2985) 55hz 99db
2x18(2954) 55hz 101db
2x18(2964) 55hz 102.5db
21" (2985) 50hz to 100hz 102.5+-0.5db
2x18(2954) 50hz to 100hz 97+-1.5db
2x18(2964) 50hz to 100hz 103+-0.5db
The posted curves bear out your listning experience 2x18" (2954) has a substantial bass peak, but lower overall response across the band width (BW), while the 2x18" (2964) and the 21" (2985) have similar response with a slight edge to 2x18 across the BW and a higher peak at 55hz. Now, how did you generate the curves? Did you feed the speakers at the same level throughout testing? Agreed, you should place the speakers identically on the surface for testing. The cabinets do not appear to be of the same type, such that they maybe accounting for the difference in SPL and BW variations. Good work on the enclosures and working on testing to determine best or your application. ...regards, Michael
21" and prolly 18" have too large an expanse of unsupported cone to be quality drivers. Likewise for the amount of motor compared to the amount of cone surface.
My 2-cents
Ben
My 2-cents
Ben
j.michael droke, I gave both speakers 40v. Then played sine waves at 20,30,40,50,70, and 100Hz. I'd say the "21" (2985) 50hz to 100hz 102.5+-0.5db" is more of 99dB. I think the dual 2954's lower resistance gives it the edge.
bentoronto, That was my initial fear of getting the 21", but they do use a rather beefy cone.
Hate to seem churlish after you've bought driver but I think this forum should record ideas for the future too.bentoronto, That was my initial fear of getting the 21", but they do use a rather beefy cone.
Sure, you can make a cone out of strong stuff but the various trade-offs of resonant freq, weight, motor, stiffness, etc. lead me to a rough preliminary impression that 15 or 12 inches is biggest-optimum, today, maybe. I also believe you gotta start with a resonance down near 20 and that is "line in the sand" for bass; hard to make a driver suspension and cone weight combo that achieves that for a big driver.
With the advance of technology, maybe 18 and 21 really are better than I imagine today or in the near future.
Ben
unless you log the voltage going into each speaker, together with the impedance curve to see the resistance at one particular frequency, you don't really know if you're feeding them the same power. Even then, it could easily be attributed to alignment differences, as you can't possibly have the same exact alignment for both considering one has dual drivers.
..and that monkey business of "doubling Xmax"? what for? Just to use the P-P version of Xmax? Quantitatively, that sort of thing is useless for when you just want to compare relative swept volume. Sd * Xmax is enough (assuming MCMs specs are correct, which they are likely not). One Vd divided by the other is enough to compare them on a percentage basis.
I know I didn't have to double the Xmax, but the cone moves two ways. Therefore I doubled it.
The reason I gave both speakers the same voltage is because I wanted the power to be relative to the amp, not the speaker. If the speaker is exactly 4 ohms it would then get 200w at 40v, whereas if the speaker is 8ohm it will only get 100w. If that amp can do 80v then in regards to the amp it is only at 50%.
I know that isn't the normal way to test speakers, but for what I'm doing it is relevant. I did do a test where both speakers got 10w, 50w, then 300w. The dual 18's where still louder for all three.
hmm.... intresting test but if you do not mind, its pointless.
with these drivers, at least.
none of them are realy subs to be honest. anything that starts to fall at 50-ish hz is a medicore bass unit.
i would choose 2 smaller drivers, the motoric power vs mass to move ratio would be better.
smaller cones have a better stiffnes than larger ones.
but, interference between 2 cones makes 100% summing of them impossible.
abcdmku,
Power = E^2/R
where:
E = voltage
R = impedance
So 40 * 40 = 1600/4 ohms = 400 Watts
or
40*40 = 1600/8 ohms = 200 Watts
best to start off correct,
dave
Power = E^2/R
where:
E = voltage
R = impedance
or
dave
- Subwoofers
- Single 21" or dual 18"
