sine waves on nos dac
I was running test tones from my computer to a NOS 1543 DAC. Up to 15khz sounded fine. Over that and it skews the output to a lower frequency. So 16khz sounds like ~10khz. The sound card is fine I compared it to a OS DAC which was fine.
Curious. Interesting that:
22.05kHz - 16kHz = ~ 6kHz
16 kHz - 6 kHz = 10kHz.
Sum and difference products like this require significant non-linear distortion to produce. However if you have a NOS DAC with a poor to non-existant reconstruction filter you can end up pumping a huge amount of ultrasonic energy into your amp. Energy with all the alias frequencies. Quite possible that some downstream component is cheerfully creating your 10kHz tone from these. Have you looked on an oscilloscope? What happens when you go to 17kHz in? What are you listening with?
