Hey guys hows it goin? So I Purchased the Zoudio 4 channel Amp with DSP. Has eq and crossovers built in. But I am having a hell of a time getting my speakers to sound good.
Is there a super simple way to measure the output of my speakers so I can adjust levels and crossover points? then maybe start playing with EQ a little bit 🙂
I built some 2 way bookshelves. tweeters are Beston ribbon tweets. Beston RT003C Round Ribbon Tweeter
And I'm running some CDT ES-400 mids. https://www.cdtaudio.com/pdf/ES-4_07.pdf
I'd think that there would be various RTA apps for your cell phone. In the past, they weren't good for the lowest frequencies but should be good for most of the spectrum.
Please study these minidsp instructions and apply!
miniDSP tutorials
Loudspeaker measurements
(Sorry there is no simple way...)
miniDSP tutorials
Bear in mind Your tweeter must be padded down 6dB since it's more efficient than the woofer.
You speaker will sound too bright.
Before tweaking crossover frequency reduce woofer amp output or make an L-Pad & put it in series with the tweeter.
any that you know of ??
