Simple answer required for a simple question...
When using 2 woofers in parallel the combined impedance is halved. Which value do you use for the crossover design calculation? The single woofer (eg 8 Ohm) or the halved value (eg 4 Ohm). Can't find a direct reference to this in the Loudspeaker Design Cookbook.
