Silly Wok-Fi build. It works!
Moderator
Joined 2004
If you have never heard of Wok-Fi it’s the practice of building Wi-Fi extender antennas from Asian cookware, sieves and the like.
Out in the barn there is a seismometer that needs Internet access to upload data. Rather than run a lot of CAT5 underground it’s linked with a Wi-Fi extender to the house network. Easy. But out there it’s at the edge of its range and likes to complain that it is "too far from the router."
So I kludged up this monstrosity. Just two aluminum pie pans glued together. Not parabolic at all, and it even won’t focus light. I poked the antennas through the back side and pointed it at the house.
It works! It gives me 12dB gain on average. Can’t quite believe it. Perhaps there will be a more elegant solution in the future, but for the moment I’m happy.
If you bend the handles of the colander down you can tuck your ears in them, it makes it more stable and won't fall off while you're on the loo...
That said, we should all bear in mind that:
I don't advise a haircut, man. All hairdressers are in the employment of the government. Hair are your aerials. They pick up signals from the cosmos and transmit them directly into the brain. This is the reason bald-headed men are uptight.
Reactions: mhenschel
