just ordered my first tube head,
Epi Valve Jr.
my thought is to run this as a pre-amp into my fm212r. pretty sure i shouldnt go into the front but is there a good reason not to use the PWR IN jack of the efx loop?
also have a handmade attenuator on the way -small attic space gets loud(!)
any advice is much appreciated
quick edit: is there a proper way to use this set-up??? thanks
Epi Valve Jr.
If you post in the Instruments and Amps forum you might have better luck with a response. The Tubes/Valves forum is more for hifi:
https://www.diyaudio.com/community/forums/instruments-and-amps.30/
