Hi everyone .
i am looking for a single coil bistable signal relay.
(not to be confused with step-by-step or magnetic relays. They are completely different relays). I may also need dual coil ones.
I need to build a volume attenuator, I would like to choose the one with the best value for money.
do you recommend me please?
I've used the Panasonic TX-S relay with the small signal option. (AgPd contacts). Careful, AgPd version contacts are only max 10V/10mA. I used this one with 2 coils TXS2-L2-4.5V-1
A 1 coil latching is also available in this range. It's a small relay, but you still hear it switching when mounted on a pcb.
