SiC Schotkys rectifiers .
Just for telling you that , after 6 years of GZ37 and GZ34 i decided to try SiC Schottkys , two 600v in series . I will keep them for the superior high frequency performance , and clean sound .
Of course i have a BG WKZ 2x100uf 500v as reservoir .
Who else had tried them in valve systems ?
Peace to all
tgtwkr
Peace to all
tgtwkr
Silicon rectifiers in Valve amps will almost kill the valves by COLD CAThODe EMMISSION..unless some delay circuit is used in the HV DC supply..about 1 to 2 minute delay is required..until the filaments heat up well...
sivan_and said:Silicon rectifiers in Valve amps will almost kill the valves by COLD CAThODe EMMISSION..
OMG! These diodes will increase your supply voltage fifty-fold?! I need some for HV experiments then! Wow!
Also obviously false, since tube rectifiers heat up in four seconds...LOL
Tim
SiC Schottkys rectifiers
I know an Audionote power that has silicon too , i m not seeing them unavoiding the problem . In the long term i believe the valve can have his life shortened . But in this case , the superior sound , worths the little damage .
The B+ was 364v , now 429v , not a problem for me , i m using
TT22 ( KT88 equiv. ) which can hold 1000v i think , all HT caps are 450v Audience brand . I bought them in USA from Tubebuilder .
the superior sound
Would you say the sound is superior in every way? I generally hate tubes and only put up with them because of the sound. Rectifier tubes i hate even more - extra transformers, heat, mercury... But so far nothing has offered comparable sound.
If the SiCs are even close to mercury they will be worth their value in gold. Where can one get these wonders?
silicon carbide rectifiers... this is the state of the art rectification today... do you use the adjustable ixys bridge (5pin), that allows adjustment of the settling time?... they re expensive though...
I'm looking at digi-key part # SDT04S60IN @www.digikey.com about $4 each Data: http://rocky.digikey.com/WebLib/Infineon/Web Data/SDP_D_T04S60.pdf are these the ones you mean?
These are Infineon ( Siemens) , and they are similar .
I tried other silicon but always seemed to me hearing some harsh
in the vocals . What i find superb , the SiCS deliver incredible highs without dryness . I have fited them in the Audionote PS2 amp too instead of 1N400X diodes , and his owner was delighted .
ALL PN junction diodes exhibit a reverse recovery spike (switching noise). Schottky diodes don't exhibit the switching noise. Until the relatively recent introduction of Silicon Carbide (SiC) parts, Schottky diodes were unusable in B+ PSUs due to PIV limitations. So, the switching noise problem with SS rectification has been solved.
As was pointed out in a previous post, directly heated vacuum rectifiers turn on very quickly. Only vacuum rectifiers with cathode sleeves turn on slowly. A simple way to slow the B+ rise down when SS diodes are employed is to use negative temperature coefficient (NTC) thermistors. Jim McShane installed NTC inrush current limiters in my H/K Cit. 2 when he overhauled it. The thermistors get the job done. No more bangs come out of the power trafo at turn on. While the thermistors only provide a few seconds delay, that's enough for the bias supply to charge up and protect the "finals" from cathode stripping.
FWIW, the "book" on Schottky diodes is that they should not be stacked. However, a Schottky diode and a FAST PN junction diode can be stacked. The combination works well. The Schottky diode blocks PN switching noise and the junction diode protects the Schottky from overvoltage. Thanks go to AA "inmate" Volt Second for the stacking synergy concept.
Eli Duttman said:FWIW, the "book" on Schottky diodes is that they should not be stacked. However, a Schottky diode and a FAST PN junction diode can be stacked. The combination works well. The Schottky diode blocks PN switching noise and the junction diode protects the Schottky from overvoltage. Thanks go to AA "inmate" Volt Second for the stacking synergy concept.
I think I want to use this in the amp I am currently building. Can someone recommend a junction diode to use with the Infineon SiC diodes? Or, anything wrong with a MURxxxx?
And the junction diode is on the secondary side and the Schottky on the filter cap side, right?
I've used the 600V Cree SiC diodes. I did my sums very carefully, simulated it on PSUD etc and was (just) within all the ratings. Nevertheless, at switch-on there was an almighty bang and a volcano as the bridge rectifier expired to the accompaniment of purple and white light . Clearly, just within ratings is not good enough. I went back to STTA512F and the amplifier has been 100% reliable ever since.
So, be careful, like all fast devices, they're fragile.
Well, for my 620VCT xfrmr, I need a rating of 877 PIV, so I thought the technique of series stacking 2 dissimilar 600V rectifiers would do the job. Are you saying that it may not work because of their fragility?
MAke sure to consider the current ratting of the diode...
The peak current can be enormous, especially for shorter conduction times, due to large C value after bridge....
Chris
Chris
I wonder why not stack them . I have two 600v in series and i think it is working well until now . What can be really harmful is the 2200uf/450v i placed in the power supply, but it sounds great.
A lot of headroom and dinamics at the whole spectrum , punch . I am thinking what will be the first thing to blow .
Martinho
Martinho
I had a 470uF reservoir and had done my ripple current simulations, yet it still blew up. I suspect it was the charging current that killed them (although it simulated within limits), but the whole experience was so alarming I didn't try again. I have successfully used the SiC diodes in a rather less stressful application.
I don't see why you shouldn't be able to stack Schottky diodes provided you bypass each one with a suitable capacitor (to swamp the "off" capacitance) and resistor (to swamp the "off" leakage), but someone else may know better?
- Tubes / Valves
- SiC Schottky rectifiers.
