SI5341 is a Ultra Low Jitter , Any-Frequency, Any Output Clock Generator
When input a 10MHZ clock , Output 22.5792MHZ or 24.576MHZ , Deterioration less than 10dbc/HZ with 1HZ
Many very cheap SC-CUT OCXO has -90dbc/HZ 1HZ phase noise , when 5dbc/HZ be degraded by SI5341 , It also has -85 dbc/HZ 1HZ , much better than CCHD957 ( CCHD957's 1HZ is 65dbc/HZ ) .
