I have a SI T-amp waiting for me at home, along with all the parts needed to do the neccisary mods. I am in the process of building a pair of bipolar Onken style enclosures for 4ohm speakers. I was wondering if I could wire the drivers in parallel if the series restistance of the speaker wire was more than 2 ohms (it will probably be more like 4 ohms)?
Thanks,
Josh
Thanks,
Josh
The SI can handle a 4ohm load but it will get much warmer than with an 8ohm load. A 2ohm load will be problematic unless you only listen at very low volume levels.
A length of speaker wire would need to be very long or have a very small gauge in order to have a resistance of 2 ohms.
You'd probably be better off using two amps, one per driver, sending each amp the same input signal.
Brian,
thanks for the responce, I'll check the resistance, but I'm pretty positive it is more than 2ohms. I use cat 5, no not single strands, I do 4.
Not sure if I told you, but I did buy the soldering iron you recommended, I've only gotten to use it to build a mic preamp. But it seems very nice. Much, much nicer than my radio shack iron. I also decided to get the soldering tweezers too.
Thanks,
Josh
Thanks,
Josh
