Hi
The original Shure M95ED cartridge is very old and the signals from one channel is weak and thin no bass. Have check the cartridge on another TT but same problem. 🙁
I have a brand new stylus N95ED.
As the same fits well on the Shure M35S, is it ok to use.
What should be the tracking force. Kindly advice
thanks
thanks
If the shank of the N95ED fits tightly in the M35S coil,then you can use it,although the M35S might have different electrical characteristics to the M95 coil.Tracking force has to do with stylus suspension-not the coil-so it will be the same as when used in the M95 coil.
Thank you my friend, your answer was perfect!!!!!!!!!!!!!!
I can now use the n95ED on the Shure M35S without worry
