I bought a 500mA Class A (+/-)Shunt Reg Kit from eBay Hong Kong, for use with an RIAA circuit I built.
The RIAA requires 2x 27v DC and pulls about 20-30mA per channel.
I can't get the shunt reg to work as I'd hoped. I have a toroidal with 18v secondaries, as recommended for the kit, and when I wire it up I get 13.7v DC per side. When I use it bipolar, of course, I get 27.4vDC, very close to my desired voltage, but I also get some small voltage fluctuations, and I can't get more than 1 volt difference with the whole range of the pots, so I don't think that's ideal at all.
I'm not sure if it is regulating properly, as I had thought I would be able to tune the voltage with the pots, and I expected absolute voltage stability.
If anybody can advise me, I would be most grateful. Here's the schematic:
If you have a 470R or 500R resistor, or two 1k in parallel, test your reg first with this passive load.
It's possible your reg is oscillating.
The schematic does not show.
I still can't see the image. You could attach an image to the post if you don't want to rely on the site where the image is hosted.
You should probably describe the psu before the reg, bridge, CRC filter, what value C, R, and C, etc.
Edit: probably something wrong with the site that the diyaudio attachments uses.
Looking at the notes on the schematic it says that 18V in gives you 13.5V out, so it seems you have it working perfectly.
OK that makes sense. Thanks to you all.
I wasn't sure if I could get the full range of voltages out of an 18v transformer, as I've never built a shunt reg before.
I tried with the jumper leads in, and it seems I can go up to about 24v DC before the lights start flickering and then go out. Without the jumper leads I get 27v DC and no lights and it's impossible to tune the voltage by more than +/- 1volt.
I'll get a 40v traffo then. Many thanks, Lucas
If I have dual 18v secondaries, that are actually reading 20v on the DMM, can I wire them in series to get 40v? I have little experience of AC multiplying, so I am a bit cautious to try it as an experiment, and I also don't want to waste the transformer.
Lucas
Lucas
No, you will have to get another identical transformer if you want more voltage and don't want to modify the power input board into a half wave voltage doubler.
What's a half wave voltage doubler? I took the plunge and wired it in series and now I'm getting a nice +/-27v of regulated supply. Why should I not go ahead and use it like that?
Thanks everybody - it all works with the 18v x2 traffo, wired in series, but my only slight concern is a lack of bass presentation. Could this be a result of using a series wired traffo?
Lucas
Lucas
So you have joined the secondaries together and disconnected what was the centre tap from ground?
There were twin secondaries - 0-18, 0-18, not the centre tapped 18-0-18 I joined together like this 0-18 + 0-18 making 0-36. The phasing issue is possible, I guess, but it seems smooth and solid in terms of voltage output, and the power supply is outputting 27volts solid as a rock, as it should.
Is it dangerous to do this series wiring of the two secondaries? Or not recommended for any other reason? I guess I am halving the VA rating, but that is still within my requirements for the RIAA.
Many thanks
Lucas
Many thanks
Lucas
So do you have the point where you joined the secondaries together connected to ground? Can you draw what you have done as I can't see how you are getting plus and minus 27V from the regulator output if you have wired it as per the supplied drawing - 18V rectified produces an absolute max theoretically possible of only 25V, and that's ignoring any losses.
Oh jeez. If I connected the joint to ground it would short my house fuses out.
An 18v x2 traffo can be used in 3 ways that I know of. The first is to power two rectifiers with 18v AC each, or a single rectifier with 18v AC with twice the rating, by wiring the two secondaries in parallel.
I am using it in the third way I now know of, which is in series, so I take the first 18v through the second, adding up to 36v. I haven't done it before, but it works. I was asking if there was a reason I shouldn't do this, as I'm no expert, but the connection should most definitely not be earthed, as this will short quite massively and trip my house RCD.
It's not a centre-tapped transformer. Not 18-0-18!!!
It is 18-0 and 18-0. What I have done is like putting two 12v batteries together to get 24v, but with AC. I haven't done it before, so I wasn't sure, but it seems to work. It definitely outputs 40v AC anyway.
Does that make more sense?
Lucas.
A schematic of what you are doing would clear up confusion.
Remember there are a lot of beginners here and it is very difficult to judge skill level on the forum. If I understand your question, a pair of 18V windings can be used separately, as an 18-0-18V or a 36V winding. Since you have plus and minus supplies in your posted regulator, if you use both windings on the positive, you will require an additional transformer for the negative supply.
HTH
Doug
HTH
Doug
no you don't.You need around 40-42V AC on the transformer secondaries , to get 27V DC with your shunt
25Vac will just about work for a 27Vdc regulated supply.
Upto 30Vac could be used if the input (CCS) transistor can take the extra dissipation.
I understand what you are saying Lucas, but it does not fit with what is happening. That is why we are wanting you to trace what you have really done and draw it. Just putting 36V in to the whole regulator theoretically cannot give you 54V in total out. 1.414 * 36 = 51V and then losses come into play.
If you have wired things correctly it is entirely safe for you to ground the PSU as shown in the schematic.
- Power Supplies
- Shunt Regulator Issues/ Questions
