should I seal the horn and 1" CD space in my speaker?
I was wondering if I should seal the box housing the 1 inch compression driver + horn in a much larger speaker. I understand sealing the midwoofer box is a given, but any benefit in sealing the horn as well? since the CD is already sealed I don't see why I should do it.
luc
I like to put a 1/2" thick horizontal partition behind the CD and fit it tightly with a thin rubber gasket so the horn/CD assembly is pressed against the edge when installed. I don't know if this actually prevents any resonance but it makes me feel better. Also it puts another bracing on the cabinet wall. I do this with woofers too.
If there is sectioning so that the volume occupied by the waveguide and driver is not making it to woofers then there is no point have the waveguide part enclosed at all, just put it top of the wooer box and enjoy potentially better diffraction performance at the same time. Lot easier to manufacture at least.
Reactions: indianajo
