If a pentode (such as EL34) has shorted, can you tell this by measuring it cold with an ammeter ?
if any elements of the tube other than the heater have a low dc resistance between them, that would indicate a short.
A resistance meter or continuity tester might be better than an ammeter. Some shorts might only develop when the valve is hot and the metal expands.
