I have a JBL PSW1000 powered subwoofer. I just finished wiring a whole house audio system and when I hooked up the subwoofer using coaxial cables with rca hook ups on the end into my Denon AVR-887, amp, my home theater speaker connectors became line voltage. I've pulled the back off the sub woofer and nothing seems amiss, like a paper clip or something bridging a connection. No evidence of any problem. Any ideas?
I had the same kind of problem. I ran speaker wires up the front wall, across the room to the back through a suspended ceiling, and down the rear wall to my rear speakers. I got a jolt from the wires when I attempted to hook up the rear speakers. Using a multimeter the wires showed 32 volts. And the amp wasn't turned on. It turned out to be an induction problem from the wires running beside a couple of overhead florecent light fixtures. Rerouting the wires away from the fixtures fixed the problem. Before you hook your sub up, test the wire with a multimeter and see if there's any voltage. If so, then you have an induction problem. If any other speaker wire is running through walls, test them too. Hopefully its your sub amp causing the problem and not the wiring. Keep us posted on what you find.
When running long runs of audio cable like that, it's always best to have the audio cables pass over electrical wiring at 90 degrees to avoid any kind of inductance from the power lines. Of course, this is if you have no other choice but to run the audio lines near power lines.
I checked the rca outlets to the sub (at the wall) and no voltage. When I cut on the sub (without the rca wires plugged in), there is 110volts at either of the rca inputs at the back of the amp. So it's seems to be entirely within the amp, not the whole house wiring.
Any ideas?
Any ideas?
Thank goodness it wasn't in your whole house wiring. That would have been a pain to redo. As for the amp being the problem, you should post your question in the "Solid State" forum. Better chance of someone there knowing what the problem may be.
lews said:I checked the rca outlets to the sub (at the wall) and no voltage. When I cut on the sub (without the rca wires plugged in), there is 110volts at either of the rca inputs at the back of the amp. So it's seems to be entirely within the amp, not the whole house wiring.
Any ideas?
So the bit about the wiring you did is not related to any of this then. Basically you plug the sub in with no other cables connected to it, then you find 110V at it's input connectors? How are you measuring this voltage, i.e. probes from outer to inner?
Yes that's right. It's nothing to do with the whole house wiring apparently. Just the Sub.
It's interesting on the testing. I get a line voltage reading on both inputs, and on the outside and the inside (sliding the probe in like the male of an rca would go). It seems the whole thing is hot. Oddly, the subwoofer seems to work fine.
All I can think of is that the sub is not connected to earth then. Does the mains lead have 3 wires or 2?
I think I know what you mean. The power wire comes into the circuit board with two wires. One of the wires is joined there with the wire going to the transformer.
Is that what you're asking?
Sort of. Does the mains lead itself have 3 wires or 2, directly where it enters the case? i.e. live, neutral and earth? Or just 2 live and neutral?
I'm thinking that the sub is not earthed Class-II rated, so the voltage you measure is nothing to worry about. Does the unit have a symbol on it that is two squares inside each other?
I'll need to check the two squares at home tonight. You are clearly way out of my league on knowledge.
It's just a 2-wire power line going into the unit, so I assume that there isn't any grounding wire (I guess just a neutral and a hot). You know I still find it wierd that the GFI doesn't trip.
The GFI won't trip because there's no current flowing to earth. The sub is plugged in with no (intentional) earth reference, so it could be any voltage above or below earth, doesn't mean it's dangerous.
If you tried to earth the sub you would probably make it hum, it's done double insulated for a reason.
with the two wire plugs like that, you're supposed to see one prong wider than the other....if I remember correctly, the wider prong should be neutral. could be that the wall outlet live and neutral pins are reversed?
Well that's what seemed wierd. I traced the power wire (ie, wire that plugs into the wall) and the one with the bigger squared spade traces to the transformer. I'm with you; I thought the squared spade of the plug was for the neutral and why would the neutral be powering the transformer. The other possibility is that the wiring in my house (a new house) is wrong.
I bought this thing used it could have been tampered with. But it seemed to work fine at my old house - who knows, though, maybe I just didn't notice it was running line voltage through the inputs.
Maybe the thing to try is to grind the squared spade so I can reverse the plug into the wall. What do you think?
Since the sub worked in your old house and not in the new one, there is a possibility that the receptacle wiring may be wrong. Easiest way to tell is get a receptacle tester.
http://toolprice.net/product/7290A?META=nextag-7290A
""The neon indicators give positive indication of circuit status. The unit simply plugs into any standard 3-wire/grounded receptacle (110-125 VAC circuits). Tests for six circuit conditions: open ground, open neutral, open hot, hot/ground reverse, hot/neutral reverse, and correct wiring. Succession of yellow and red lights provide indication of circuit status or specify which wire is defective."" I have one of these and would never be without it. If the receptacle tests fine then the problem is in the amp as was suggested in the "Solid State" forum.
By all means test the mains socket (in fact I urge you to do so) but the whole point of a double-insulated device is it does not matter which way round you have live and neutral, so that's not the fault.
As I said, if the sub is 2-prong cord only it is not earthed therefore it will always be floating at some random potential away from ground.
- Subwoofers
- Shocked by Subwoofer thru Speaker Outlets of Main Amp
