hello,
I´ve got a Display from a Dell c800 Latitute. The laptop is broken, but the Display still works. Now I´m searching for a possibility to use this Display on my Computer. Exept of the wireing plan for the Display I also need the wireingplan for the electricity.
Does someone know about how to connect this Display? It`s a Sharp LQ150U1LH22. 15" and 1600x1200.
Thanks.
Phil
Thanks.
Phil
You will require
an LCD controller card as well as the appropriate TTL or LVDS cable to attach the screen to your controller card. Your video card will NOT work for this. If you go for a controller card you MUST have the pinouts for the screen you have, you need thede to spec the card and cable from the manufacturer.
If you decide to rid yourself of this panel let me know... I have a controller card that has multiple BIOS's for various panels.
ds
ds
thank`s for your help...
i also had the idea to use the laptop graphiccard in my computer but this also won`t work...
anyways, cya
anyways, cya
