sharp 15 & 17 " lcd tv
Found these tv lcds at my local office depot.
Would they work for diy projector?
How about striping them?
1) Sharp 15" LL-M15X1U = $250.
2) Sharp 17" LL-M17W1U = #350.
15" specs =
General Features:
Pearl White
15-inch TFT LCD
0.297 pixel pitch
1024 x 768 resolution
Brightness: 350 cd/m2
Contrast ratio: 350:1
25 ms response time
160-degree horizontal view angle
135-degree vertical view angle
181 Channel TV Tuner
Built-in speakers
On screen display controls
_
Front Panel Features:
Power LED
Remote Sensor Window
Headphone jack
_
Back Panel Features:
Standard 15-pin VGA connector
Audio in
DC 12V input
Audio/Video inputs
S-Video connector
Coaxial Antenna connector
_
Side Panel Features:
Input button
Menu button
Enter/Bright mode
Channel up/down buttons
Volume/bright buttons
Power button
_
Power Specifications:
DC 12V, 2.5A, 30W
_
Remote Control Features:
Power
PC
TV
AV
Sleep
Menu
4-way buttons
Enter
Bright Mode
Bright
Display
CC
MTS
Mute
0 - 9 numeric keypad
100 numeric keypad
Volume +
Volume -
Channel up
Channel down
Flashback
_
Regulatory Approvals:
UL
FCC
_
Retail Package Includes:
Sharp 15-Inch TFT LCD Flat Panel Color Monitor
Manual
Remote Control
Two (2) AAA batteries for remote control
Utility disk CD
Coaxial cable
15-pin VGA cable
Audio cable
Cable clamp
AC adapter (100-240V, 50/60Hz)
Power Cord
_
Notes:
Model: LL-M15X1U
UPC: 0 74000 04790 7
LCD displays may have cosmetic imperfections that appear
as small bright or dark spots. This is common to all LCD
displays used in products by all vendors and is not
specific to any one vendor or brand. Below are the
acceptable amounts of "dot defects" for LCD displays
that
we sell:
15-inch:
Total Defects: 6
Bright or Dark Dots (random): 3
Bright or Dark Dots (2 adjacent): 1
Bright or Dark Dots (3 adjacent): 0
Minimum distance between defects: 15mm (bright to bright
dots); 5mm (dark to dark dots)
17" specs. =
Sharp17-inch WXGA LCD VGA Monitor w/TV Tuner
_General Features:
WXGA LCD Computer / TV Monitor
Ultra-Thin Profile
Beige and Silver
17-inch viewable multi-function LCD monitor
Built in TV tuner (NTSC)
V-Chip block
Antenna and 2 AV inputs
Remote control (two (2) AA included)
Multiple view modes
On screen menu
181 channel tuner
PIP mode
_
Display Features:
Pixel Pitch (h × v): 0.289 mm x 0.289 mm
Display Colors: 16.19 million
Contrast Ratio (typical): 600:1
Brightness (typical): 260 cd/m2 (pc mode)
Brightness (typical): 400 cd/m2 (TV/AV mode)
Response Time: 25 ms
Recommended Resolution: 1280 x 1024 / 60 Hz
_
Audio In/Out
DC input connector
_AV-IN 1 connectors:
One (1) RCA video input
Two (2) RCA audio input
One S-Video connector
_AV-IN 2 connectors:
Three (3) component connectors
Coaxial Antenna input connector
_
Side Paned Features:
Input button
Menu button
Channel up/dowm button
Vol/bright button
Main power button
_
Remote control features:
Power button
Freeze button
Sleep button
Up/Down/Left/Right buttons
Bright mode button
CC (close caption) button
Channel buttons 0-9 and 100
Input button
View mode button
PIP (picture in picture) button
Menu button
MTS button
Volume buttons
Channel buttons
Flashback button
_
Compatibility:
Windows 95/98/2000/XP/ME
Macintoch
I just picked up a Sharp Aquos LC-13E1U off eBay.
You can seperate the LCD from the Electronics.
All I need is (3) UL2896 FCC Flat flexible cableswith.5mm pitch. A 20 conductor, 30 conductor and a 48 conductor with same side ZIF connections 250mm long
does anybody know a supplier?
Specifications
Panel Type 13" Active Matrix (a-si TFT) LCD1
Pixel Resolution 921,600 dots (480 x 640 x R/G/B=VGA)
Video System NTSC/PAL/SECAM
Brightness 430 cd/m2
Lamp Life 60,000 hours2
Viewing Angles 170ºH / 170º V
Audio System 2.1W + 2.1W
Tuner Type Electronic PLL Tuner
Aspect Ratio 4:3
Contrast Ratio 500:1
Color Temperature 8,000º K
Component Input Y/Pr/Pb x 1
S-Video Input 4-pin DIN x 1
Composite Video Input RCA x 2
Power Consumption AC 35W
Dimensions (13 17/64" x 12 19/32" x 2 21/64"
(without stand)
Weight 7.3 lbs. (without stand)
1Actual screen size 13 1/16" measured diagonally.
