SG3525 feedback with opto
If you use an optocoupler, you will also need something providing a reference voltage to which the output voltage is compared. Then the difference between those two voltages is converted into a proportional current, some gain may be added (a TL431 is the usual way), and then this current is fed to the photodiode. With such a feedback scheme, adjustable output requires just a variable voltage reference.
